What would happen if your ac power system uses 240V and you are using a 230V-115V step down transformer?
Would it degrade the winding faster?
Why is there a 230V-115V ac? what countries use it?
You're talking about that step-down transformer you bought.
Step-down transformers are designed to turn a 230V Euro-style supply into a 120V North American style output. They are designed to do this all day, all night, for as long as the device lasts.
The life of the device will be decided by its build quality. Is a General Electric product better than a brand-you've-never-heard-of East Asian made cheapie? Oh, you bet it is. Still, a transformer has no moving parts, so expecting long life is reasonable.
I really don't understand your question. First a transformer (xfmr) which accepts a single phase 240V input does not really step down to a 230/130V output the voltages are nominal, meaning they are virtually the same. So now that we have that straight, the named output of 230/120V simply means that you have added a grounded center tap to the output coil and you now have a dual voltage output. 230V across the phase and 120V grounded neutral.
Technically speaking it would not degrade a winding it is simply the way it is made.
These type of xfmr's are used anywhere you would need to split a voltage and add a neutral.
Hope this helps
Around the world, the closest thing to a standard mains voltage that exists is referred to interchangeably as 220V, 230V, 234V, or 240V -- it is extremely rare these days to run into a device that cares enough about mains to care about the difference between 220V and 240V on the input, and most mains supplies have a broad enough voltage tolerance (+/- several %) anyway that a device that did care that much would need special care and feeding anyway.
So, go ahead and plug your transformer into 220, 230, or 240V -- while the output voltage will vary slightly between the different input voltages, it should still be within specification for whatever you plug into the output.
