While moving, I scratched the vinyl flooring. It is a "wood" laminate flooring, where the planks support material with a wood print veneer (as mentioned in Can/Should I seal laminate "wood" flooring?). As far as I have been told the flooring is design "Life 710670003" by https://www.project-floors.com.
The scratch is running perpendicular to the grain. It measures about 1 metre in length and about 1.5 millimetres in with. I have no idea how to measure the exact depth. Apart from a few millimetres, the veneer is not ripped apart, only pushed into the base material.
The landlord is not amused since the scratch is located in the middle of the room, it is well visible and it can be felt when walked on. I want to try to fix the floor visually and structurally as much as possible. At minimum, I would like to level it out to avoid dirt accumulation.
Ideally, one would replace the affected planks. However, there are no spares available. As it turned out, this flooring has been discontinued altogether. Hence I cannot purchase replacements either. Divot replacements (like discussed in Divot repair in laminate flooring) are out of the question, too.
The producer Project Floors does not provide the technical details of this particular flooring (due to discontinuation, probably). For this reason, I do not know with what materials I am dealing with exactly.
Most flooring patching methods are geared towards flat-colour PVC and are not applicable to my case. There are repair methods involving fillers and/or hard wax, but they seem to apply exclusively to hardwood flooring.
Is there anything I can try or is this 'bout a scratch, but ultimately a lost cause?
