Does anyone recognize the brand of the faucet in the image below, so that I can attempt to disassemble and inspect parts? Secondly, the right-hand handle sticks; is hard to turn off completely, and leaves water leaking from the spout. Any advice on how to fix this problem?
there may be labels attached to the pipes underneath ... you have said what type of valves you have (compression or washerless) (washreless would be 1/4 or 1/2 turn with hard stops) – jsotola Feb 7 '18 at 16:38
Tommie, you can discontinue the practice of adding the comment notice at the top of your questions. That goes without saying on SE networks. :) – isherwood Feb 7 '18 at 21:40
It looks much like this one--wow ... not cheap--found by doing a web image search for "antique brass faucet".
This is the install document. Item 16 is a setscrew that you loosen so that you can remove the handle, and expose the cartridge assembly. Then I guess that you would loosen a retaining ring and pull up on the cartridge assembly.
Do not forget to shut off the water before doing this.
Here is the manufacturer. You could email them.
Could you offer any advice on part two of the question (how to disassemble, inspect, and clean these faucets)? - I'm a novice in this area but I'm handy and learn quick. – Tommie C. Feb 7 '18 at 19:56
This answer addresses the critical points of disassembly. Cleaning of a faucet mostly involves dissolving calcium buildup. However, cartridge-type faucets generally don't need much cleaning if the cartridges are being replaced. There's plenty to be found on that with a search. – isherwood Feb 7 '18 at 21:45
