I purchased a craftsman push mower 2 years ago. It's be stored inside and been used on our personal lawn for 2 summers.
A week ago it ran wonderfully, then it started running poorly. Eventually getting to where I couldn't even cut the grass. I'm not mechanic by any means, but have tried the following:
  • Cleaned air filter
  • Dumped out old gas and replaced with new.
  • Took the Carburetor apart and clean the entire thing.Sprayed parts with brake cleaner, as that's what i had as opposed to Carb cleaner.
  • removed spark plug and screwed back in.
It starts every time on the first pull, however it just runs weak and chugs a long. I noticed that when I tip it back - meaning front wheels in the air, it runs significantly better. When I put the mower deck back level, it sputters along. The oil level appears to be low if anything. Not significantly, just lower than suggested.
any help would be appreciated.
    Typically carb not cleaned properly. On my honda carbs circa 1980s I can think of 8 different orifices I spray through. I also usually dip the carbs in carb cleaner even if for a short time. I also learned name brand carb cleaner works better than the generic stuff so i use the name brand stuff internally and generic stuff externally. Blowing with air is also needed after spraying. If you are not practiced at it, just buy a new carb and see if it fixes your problem.
    – Damon
    Sep 11, 2017 at 8:17
    If it runs like normal when you tilt the mower back, then you have a carb issue. Could be a float issue, could be a small fuel or air restriction as well. When level the float might not be moving freely enough to allow the fuel to siphon in at the proper amount. I agree with above...buy a new carb and try that, they are usually cheap.
    – Jeff Cates
    Sep 22, 2017 at 18:54
  • any chance you hit something hard (ie rock) with the blade? Possibly sheared the flywheel key.
    – agentp
    Dec 1, 2017 at 3:15
How far apart did you disassemble the carb? Did you clean the metering valve assembly? these are usually super tiny that you need a single strand of stranded wire to get in there and clear the ball bearing or check valve parts.
If you provide the model # I'll try to find the engine diagram and point it out.
You also want to check the float and make sure it is seated correctly and no liquid inside of it.
