I'm looking for a wall outlet adapter converting two outlets to six, like this GE one. However, for reasons I don't comprehend, that adapter (and all its clones) have only one active plug, the other being a plastic dummy. Adapters that plug into both outlets do exist (example) but the outlets they provide are too closely spaced for most wart transformers.
2If the outlets are too close together, then use the short "pigtail" extension cords for some of the receptacles.– Jim StewartCommented Aug 8, 2017 at 11:18
Who cares? One set of blades is good for 20A, so perfectly adequate for 12A continuous, which is all you should be putting on a 15A circuit (blades parallel). If they are all wall-warts, that just won't be a problem. If you are getting heating, it's because your receptacle or adapter has a problem. It's rare for a receptacle to be a Cheese piece of junk, but very common for an 'adapter' to be. GE is as good a brand as they get, I sure wouldn't put something called "Fosman" in an outlet. UL listed, yeah right.– Harper - Reinstate MonicaCommented Aug 8, 2017 at 16:52
Advertising (or marking) a product as "ETL listed" would be fraud if it's not actually true. Anyone having one can look up the model number at Intertek, e.g, the one shown in OP's example (Fosmon).– UpnorthCommented Aug 8, 2017 at 20:15
Add a comment
1 Answer
The reason for the one active plug is because the one you show is rated 15A which is what that configuration will carry so there is no reason to have two. On your other question you might look at the ones that have USB ports and outlets. The ports wouldn't require a transformer. last resort would be an old fashion ugly three way or cross adapter.
Good Luck
1Good answer, and for clarification I'd like to add, for the OP, that the top and bottom of an outlet are not two circuits. They are the same circuit. It really does sound like you just need a power strip.– NPMCommented Aug 8, 2017 at 17:10
