I need to remove the stem for the faucets from my bathroom sink. However, the people who built this house (10 yrs old so fairly new home) messed up. I think this is what happened. They cut holes in the granite and plywood for the sink, faucets and spout. They installed the faucet and spout first, then tried to undermount the sink. However, since they didn't measure correctly, the rim of the sink hits the hot and cold water faucet/stem. They barely cut enough of the sink away so that it fits but now, I can't turn the retaining nut on the stem because the sink is in the way.
Here's a photo of what happened photo of what happened.
My question is how do I cut away more of the rim of the sink so I can remove the stem? One person suggested to get a "Dremel" and cut away the rim from the retaining nut without removing the sink (less work)
Someone else suggested to take the sink out (which means cut the sealant and caulk, remove the wood holding the sink, remove the piping) and cut it with a tile cutter. Or instead of cutting, do this every time we need to replace the stem, which seems like a lot of work.
Which is the best/easiest way such that a noob like me won't mess up? Both ways I'm a little concerned because if I mess up and destroy the sink, I have to replace the granite, along with the sink since I don't think I'll find a sink that is the exact size as the existing hole.
  • If you are replacing the faucet, could you unscrew the faucet from the top and leave the nut under the counter in place? A pipe wrench would mar and scratch but as I understand it you are replacing the whole faucet. Then with the faucet removed the nut would fall away. Aug 5, 2017 at 20:33
  • Surely that square plate is not integral with the (octagonal?) nut, is it? Aug 5, 2017 at 20:34
  • When you say you are replacing the "stem" do you mean the entire faucet? Aug 5, 2017 at 20:39
  • @JimStewart, thanks for your interest in helping me. In short, yes I am trying to replace the faucet. The handle is stuck on the stem/valve/cartridge and someone suggested to remove the stem so I can try to get more leverage to remove the handle. I don't want to get too much into why I need to remove the handle since it's another problem. I don't know why the square plate is there for. I just put a crescent wrench on the nut and tried to turn (w/o looking closely first). When I couldn't turn the wrench, I saw that the builders did a poor job and messed up.
    – Classified
    Aug 5, 2017 at 22:31
  • The copper supply lines going into the faucet are part of the faucet and you could disconnect those from the supply lines and cut those off flush with the bottom of the faucet. This will make it easier to get a wrench on the nut. Aug 6, 2017 at 11:15
Since you are intending to remove the "stem" of the faucets I would concentrate on that instead of the sink itself. Seems to make sense to concentrate on the goal instead of getting sidetracked with these other details. (I have to assume that removal of the faucet is all about replacing it with something new).
To that end I would still recommend a Dremel tool with a cut off tool and a decent pair of eye protection goggles. Use the Dremel to cut completely through the retaining nut on two or three sides if possible. See cut areas as suggested below on the flats of the nut so there is less to grind through:
Once cut through you can use a flat blade screw driver to widen the cuts and pull portions of the retainer nut free from the stem threads. Since we are assuming replacement here the fact that the Dremel cut off tool will grind into the stem threads is of little concern.
When you go looking for a faucet assembly look carefully for one that has a long threaded part that will extend down below the lip of that butchered sink. This will allow you to slip some tubing (even a short piece of PVC pipe would work) over the threaded part offset where the new retaining nut and washer will tighten to. From the looks of it the tubing should be able to clear the butcher slot cut in the sink lip. If the PVC type tubing has too thick of wall a piece of brass drain pipe would work too. Just make sure the tubing is cut nice and square on each end.
  • Thanks for helping me. I don't want to replace the whole faucet set if I don't have to. I was trying to remove the stem to try to remove the handle to change the rubber seal. It's stuck and someone suggested to take the stem off to get more leverage to remove the handle and change the seal. I'll take your advice as a last resort but thanks for your interest in helping me.
    – Classified
    Aug 5, 2017 at 23:19
