I need to securely attach a wooden plank to a banister. The plank is temporary so I need a method that won't do permanent damage to the banister (I do not mind plugging holes and using touch up paint if needed)
Please see attached diagram. I don't know if nails or screws are the right approach. Or if I need to drill holes and use one of those plastic tube inserts.
I need to do this because I need to attach a baby gate to the banister but the irregular shape of the banister prevents me from using any pre-made baby gates.
Use screws
  1. The baby gate will tear the banister up so you need something to protect it. A 2x4 is a good solution
  2. Screws come out easily and leave small holes. 2 screws total (I'd suggest 3" myself) should do the trick. Wood putty the holes and stain and/or lacquer
One tip: put something like a piece of plastic (maybe a plastic bag) between the banister and the 2x4. The lacquer finish (or paint) might get damaged by being sucked up to the 2x4
  • Thanks. Do I have to use a wood anchor for the screws or do they go directly into the banister.
    – V Maharajh
    Commented May 19, 2017 at 23:45
    I'd just use a drill and power them in directly(anchors would need an even bigger hole). If you're worried about puckering or splitting, pre-drilling is advisable
    – Machavity
    Commented May 19, 2017 at 23:46
