I was wondering how you would go about doing this. I have a 48x12x1 Bamboo blank. I'd like to cut the thickness in half so I have 2 planks. Perfect 0.5 width (with blade) does not matter as long as it's cut in half.
My first thought was to square up the 12" high plank on a table saw and use blade 6-8" high, then cut and flip then planer? Do table saw blades even go that high?
There's a Woodworking club nearby I could use. If I can't do it myself, I can ask one of the guys, but I'd like to give this a go.
Thanks for any help.
