I'm trying to mount a ceiling fan on an older electrical box... I need to buy some longer screws so it will fit, does anyone know what the standard size screw would be for the ones in the corner ? Please se image .
You are looking for a #8 I believe. In your Hardware store pick up a box carry it to the screw aisle and verify to be sure it could be #6 neither are expensive .50 for a pack each.– KenMay 18, 2017 at 3:38
1 Answer
Most likely 8-32, possibly 6-32. Watch out, 8-32 is fine thread.
The -32 is intentional as it assures enough thread engagement.
Make sure you are hanging your fan by more than just a couple #8 screws!
1If it's confusing, buy a box and use the screws from that box. May 18, 2017 at 15:39
