Am having to install covers to several different types of electrical connections boxes in my house. Some are round, blue ones and some are a grayish tan with corners rounded. None of them have cover screws in them, so I am having to go buy screws to attach the covers. What type and size of screws are need for each type of connection box?
    Generally the screw you need should come with the cover. Typically cover screws are 6/32.
    – Tyson
    Feb 18, 2019 at 18:59
  • Do your faceplates not come with screws? Feb 18, 2019 at 19:34
Most hardware stores I have been to had a specific electrical screw section in their fastener area. They should basically be labelled as electrical box cover screws, and you can find them in all kinds of versions: long/short, metal/plastic, and different finish colors.
I maintain a supply of #6-32, #8-32 and #10-32 (which is a fine thread) in my electrical screw bin.
Code requires a -32 thread or finer for grounding screws, because a standard steel junction box has a metal thickness such that -32 will give enough thread engagement to be secure. -40 would be allowed; -24 would not. By coincidence, NC (National Coarse) thread sizes are 6-32 and 8-32, and NF (National Fine) is 10-32. And that is why this tool exists.
I will attempt to answer but, Could you provide photos, your description almost sounds like wire nuts both made in tan and blue. I think you are talking about cutthler hammer panels the gray/tan but there are a large number of different manufactures of the blue ish covers.
load center cover screws are not standard screws. They have a larger head, some have a fine pitch like Siemens ects2 or Square D S106 then almost wood screw look for Eaton LCCSCS. These are closer to #10 size with a large head #2 square drive or flat blade screwdriver and the first 1/8" is not threaded to get the screw in the hole. I know quite a few electrical inspectors and home inspectors that look for the correct screws this is why I provided the part numbers of the main ones I keep spares of.
    I think he's talking about ordinary junction boxes, not loadcenter cabinets... Feb 18, 2019 at 19:40
  • I was not sure but the colors I thought load centers that's why I asked for pics.
    Feb 18, 2019 at 19:42
