I have a halogen light [ikea brasa 360] where the plug/transformer is missing. Image here https://i.sstatic.net/GMoWa.jpg I did a bit of research and figured I could cut the cable and solder the wire to that of a plug/transformer rated at 12v. When i cut the cable on the lamp i found three wires red, yellow and blue. Given that teh transformer [from a hard drive] had only two wires I went through them all two at a time until i got a light. I joined them [yellow and blue] and the light lit but it flickers at a steady throb now and doesn't light properly. Can anyone advise as to what i need to do. As you can tell I am far from an expert in these matters. Any help would be gratefully accepted. Thanks
You have probably replaced a regulated power supply (this creates a constant 12V) with an unregulated one (which supplies 12V on average, but the actual level fluctuates). Or the power rating of the new transformer is too low.
You need a regulated power supply that can supply not just the right voltage (V) but also enough power (W).
Looking at the adapter in the photo, it shows 9.6V / 11.5V ~ .
This shows a AC output on the adapter with two voltage ranges.
Not knowing which lamp you have and if it has a high low setting, but based on the three wires and the adapter it looks like you need a dual voltage AC output adapter. Then all three wires will be used and the lamp will function proper if it has nothing wrong with it.
Thanks you very much for the suggestion and help. I'll try and track one down but from what i can see the ones i find online have two wires and not three. amazon.com/AspenTek-60watts-Voltage-Waterproof-Transformer/dp/… The lamp does have three setting, off, high and low. If i am not being too much of a pest could you give me an example of the type I need. Thanks in advance.– JeanCommented Oct 7, 2016 at 11:47
I would take a tour of your local thrift stores (goodwills and such if you have them). Look for a power pack that shows output values in the range of 9VAC to 12VAC. Finding a dual voltage version will be vary unlikely, but the 12VAC output ones I have seen quite often in the thrifts for 2-3 dollars. If you do find a 12VAC and have some electronics understanding it is possible to add a resistor in for the third wire as a dropping device for a low light position. Commented Oct 7, 2016 at 13:42
