The bulb looks like this.
Bayonet-mount
It's been mildly broken from my earlier effort to remove the light. I've tried holding at the base, pushing it in a bit, twisting left/right and then trying to take it out, but this hasn't worked. I've had this fitting for many years but have never had a problem removing the bulb before using this procedure. I can still twist left/right but for some unknown reason the bulb will not come out when pulled.
The light fitting itself looks like this
Fitting
  • Classic answer: use a cut potato and push it into the socket. Aug 6, 2016 at 13:59
I would disassemble the fixture so you can get to the socket and bulb itself. Normally you push in, turn left and pull, but it sounds like something is wrong. Go with a quality LED and you'll never have to replace it again.
