I've been struggling with this light bulb for hours.
I tried to un-screw it to the left or right but it didn't rotate at all.
Please help me.
1 Answer
Some types of compact fluorescent (PLL, PLT) have a push-in fitting. Try pulling straight out.
Photo by ikiwaner, Creative Commons Attribution-Share Alike 3.0 Unported
P.S. While you are working on that, you really ought to fix that loose earth/ground connection with a bolt, nut, washer and maybe a crimp-on ring-connector. Or something similar. —
P.P.S. broken compact fluorescents may need special cleanup
It looks like there may be a push in release tab at 1:30 o'clock on the base. Try pushing that tab in and pulling the base out. Use a garden glove to protect your hand Jan 3, 2017 at 15:33
