12
TL;DR
Can I fix the sag by slowly jacking up the ridge, simultaneously tightening some steel cables attached to the top of each wall?
Measuring between the top of the wall and the top of the ridge, I see about a 3.75" dip in the middle.
Details
I have a 16x12 shed - the Home Depot variety - that came with the house when we moved in 4 years ago. I'm guessing the shed is about 10 years old.
The roof is sagging a few inches in the middle:
Also notice the eaves are bowed upward in the middle. To me, this indicates that, as the ridge 2x4 has sagged, the bottoms of the joists have pushed outward. Thus, the wall acts as a sort of fulcrum, and the part of the rafter that goes past the wall, supporting the eaves, gets lifted.
It also looks like the walls have bowed outward just a bit:enter image description here
(Please no comments about the horrible attempt at adding a soffit vent. It's getting replaced.)
And, here's a shot of what the inside looks like: enter image description here
Note that the long, newish 2x4s in the picture are not attached to anything - I just set them up there temporarily to get them out of the way. I intended to use them as joists, which are sorely lacking in this structure.
So, my thought was this, which may be completely insane as it's cobbled together from a little physics and engineering background, Internet "research," and a working knowledge of what's available at the local Home Depot and Tractor Supply.
  • Attach braided steel cable along the short span (perpendicular to the roof ridge), between bottoms of the rafters, about every other rafter (which are on 24" centers, unlike the 16" walls. (Might be better to attach to the top of the wall?)
  • Support the center of the ridge with a 4x4 and a floorjack, probably tying the 4x4 to something to keep it from falling on me when it inevitably slips off of the jack.
  • in small increments, jack the ridge,
  • tighten the turnbuckles to bring the walls in and the rafters up
  • rinse, repeat until the sag is gone, or at least far less severe.
  • add more joists and rafter ties (which are also completely absent, except for one that is attached way too high to provide much structural benefit.)
Am I way off base here? If so, suggestions on alternate approaches?
16
Your plan is exactly right, except that you don't need such heavy-duty hardware to do the jacking/winching. Even a pair of motorcycle ratchet straps or a come-along is going to do the job, especially if you jack up the ridge board. I think it'll all move easier than you anticipate. Just make sure you have solid connections to the walls so you don't have any sudden surprises if something lets go. Maybe lag some loops to the top plates.
One or two rafter ties, well-attached, will prevent the problem from happening again. You could probably get away with keeping them a foot or so above the wall plates, too, if headroom is at a premium.
Good luck.
    And I happen to have a large come-along sitting here. Headroom is not a problem - the walls are 8', I'm 5'9. I was thinking of leaving the steel cables in place, but rafter ties have been used successfully for a long time. :) Thanks for your help!
    – 3Dave
    Jul 11, 2016 at 18:36
  • Could you elaborate on "lag some loops to the top plates?"
    – 3Dave
    Jul 11, 2016 at 18:47
  • Anything you can stick a bolt through and hook your cable to, really, as long as it's robust enough to hold. Look at load ratings and shoot for a few thousand lbs.
    Jul 11, 2016 at 19:19
  • Cool - got it. The interior isn't finished out, so putting a bolt through the top of the wall isn't a problem.
    – 3Dave
    Jul 11, 2016 at 19:20
