A couple of years ago I replaced a ceiling light in the MB with a ceiling fan/light using a remote control wall switch (light off/on with dimmer; fan off/on, high, med, low). There is only one switch. This worked great until I plugged the vacuum into the wall outlet nearest the switch, which was apparently wired to the wall switch. This action immediately fried the wall switch and the bottom half of the outlet ceased working. Note, it was only the bottom half of the outlet that caused the failure as the top half of the outlet was in use with a clock radio without a problem.
What I now wish to do is: 1) Put in one wall switch that will turn on/off the power to the fan/light both. 2) Disconnect the outlet from the wall switch so that the outlet, both top and bottom, are always on and not effected by the switch. 3) Then I will wire in a fan/light remote control that will work when the wall switch is on but not when it is off. This part I can do.
The Question: What is the proper wiring configuration for the switch and the outlet to meet the above conditions?
The Current Wiring Situation: The Switch: Three sets of wires, including white and black, white and black, white and black and red. All having a grounding wire. The Outlet: Two sets of wires, including white and black, and white and black and red. Currently it is wired as such when looking at it as if looking at the BACK of the outlet: Upper Right (UR) is White, Lower Right (LR) is White, Upper Left (UL) is Black, Lower Left (LL) is Red. Both sets have a grounding wire. There are a total of four outlets in the MB. The Ceiling: One set of wires which is white and black with grounding wire.
Thanks for your help
Correct, it is a wireless remote @ThreePhaseEel.
10
  • What model of remote control are you using? Jul 3, 2016 at 23:36
  • Hmm, not sure how to answer that. How about a pic? Or can you tell me more specifically what you need to know, as I don't see a brand name.
    – F. Hooper
    Jul 4, 2016 at 0:03
  • A picture helps -- make sure the label on it is readable Jul 4, 2016 at 0:37
  • No luck with the pic. The label: JY326B(5+6uF)
    – F. Hooper
    Jul 4, 2016 at 0:49
  • Or do you want the schematic label, so small I can't read it, but is included on paper? AC Power Input: Black Wire AC in L; White Wire AC in N. To Fan Motor from Receiver: fan/light/neutral White Fan/live Black Light/Live Blue
    – F. Hooper
    Jul 4, 2016 at 0:51
Your problem is actually very easy to fix based on the information you've given -- simply replace the outlet with a new one without breaking the tab off the hot side, connect the black wire to the hot screw on the outlet, and cap off the red wire at the outlet with a wirenut instead of connecting it to the new outlet.
  • OK, that sounds great. I still don't know how to wire the switch which has three sets of wires as described above. I'm thinking it must need a double switch like almost all the other bedrooms have: one to control ceiling light, one to control the outlet, except I don't want the outlet controlled by a switch.
    – F. Hooper
    Jul 10, 2016 at 1:25
  • Post photos of the switch box configuration and we can help you with that @F.Hooper Jul 10, 2016 at 1:40
