Professional testing of Mold or Lead or Asbestos can be expensive. I just found some home testing kits that require you to take and submit samples.
Are these a good cost savings approach with adequate results or should I consult professionals?
Seems reasonable to me. IMO, if you are able to send samples to a lab, that is going to be more precise and certain than any kit you could apply in the field.
The only thing I don't like about it is that it creates a third-party record, which means now you must engage any formalities of dealing with those things, and the formalities can be more annoying and expensive than the actual work.
