I'm considering replacing an outdoor lighting fixture with an LED motion-sensitive fixture, but I'm not sure how to safely do the wiring.
The location is protected (under a porch) but still needs to be weatherproof. Here's the existing fixture and mount:
The obvious replacement would be another lamp that included its own box cover, so that its wiring would be covered and protected. But, the fixture I like doesn't include such a cover:
You can see it's meant to be screwed into the wall, but doesn't cover anything. The power cable ends with bare wires which are meant to be wire-nutted to the supply wiring, probably inside a junction box. But, how do I get the wire safely into the junction box while keeping things weatherproof?
One option would be to replace the lamp's power cable with one ending in a grounded plug, and install a weatherproof outlet box. But that's ugly and complex.
Are there weatherproof junction box covers that include provisions for sealed entry of cables?
