It seems hard to enter service mode. what I do is just press "Signal" then "Delay start" then "Signal" then "Delay start", but it doesn't work. what's the exact steps?
1 Answer
It should work with below steps:
- Press "Power" button to stop current mode if necessary.
- Unplug power line for 30 seconds.
- Open the door, then plug power line but do not press "Power" button.
- With in 30 seconds, after plugin power line.
- Close door.
- Press "Signal" then "Delay start" then "Signal" then "Delay start".
- Door will be locked and show "t01" on display.
