I am finishing a basement and I am not sure if I need to install GFCI or AFCI outlets. Is it better to use a GFCI/AFCI breaker instead of the outlets?
NOTE: the finished basement will be used as a home theater/media room. There will be a dry bar also.
  • @isherwood made the changes you requested.
    – Programmer
    Commented Jan 22, 2016 at 16:16
If it's officially considered "habitable space", then it's a finished basement and GFCI is not required.
AFCI protection is required. An AFCI breaker, is probably the cheapest and easiest way to provide the protection.
