I installed a new faucet. I replaced the old PVC pipe that connected the faucet to the water line with the supplied pipe.
The supplied pipes are not PVC. They're instead covered in some kind of mesh.
Previously, the old PVC pipe was cut and joined to a splitter that channeled water to the under-sink filtration system.
Is it possible to cut this mesh-type pipe and join it to a splitter as well? What's underneath the mesh? Will the mesh interfere with anything?
Pictures ##3
The first picture shows the old hose. Note how it's all PVC - no fancy mesh or whatever. The black hose goes to the filtration system.
The second picture is a close up of the T fitting. What kind of T fitting is this? It seems as if all the hoses were pressed into the T fitting - there doesn't appear to be anything that can be unscrewed. What would I look for at the hardware store? How would I remove the black hose? I tried pulling it out but that's not getting anywhere.
