I am replacing a floor drain which required me to saw off the old drain which was cemented to 4" schedule 40 PVC. I had limited room to do this (Please see the picture below; I had broken out the concrete and gravel/earth around the drain), so I used a Dremel with a plastic cutting blade to cut from the inside of the pipe, leaving a slightly jagged pipe end. The new drain has a hub connection that fits over the end of the pipe I've cut. I've read that the end of the pipe should be as square as possible to maximize the quality of the hub connection. Right now the cut isn't square and I'm having a hard time figuring out how to make it square. As such, I have a few questions in one here, because I'm not sure what my options are.
  1. How important is the squareness? If one side is off by a third of an inch or so, will this really matter once the hub connection is solvent cemented onto the pipe, considering there will still be a couple of inches or so of bonding surface?
  2. If the squareness is important, what are some good ways to cut the pipe, seeing as I have very limited room to work with it from the sides?
    • I have considered sanding/grinding from above until the edge is level. Would the PVC dust be dangerous if I were applying suction from a shop vac (with a HEPA filter and dust bag) and wearing a respirator?
    • I had hopes there would be a tool that could be placed over the end of a 4" pipe and turned to make a squared-off cut. Does any such tool exist? Is there anything at all that can squarely cut 4" pipe without needing much room at the sides of the pipe?
it is image of pipe of drain
  • Use a mitre box. Apr 18, 2016 at 11:43
    @CarlWitthoft - Did you even read the question? Your comment is completely useless in this case. If this was your attempt at humor then eve that is a fail.
    – Michael Karas
    Apr 18, 2016 at 11:53
    You could knock off the high edge with an orbital sander, perhaps, but I don't see why 0.33" of irregularity would matter one bit in this situation.
    – alfreema
    Apr 18, 2016 at 12:42
  • @alfreema - I do have an orbital sander, but am a bit reticent to use it for the fear of releasing toxic dust or vapor. What thoughts do you have on why a square cut is normally needed and why it may not matter as much in this case?
    – bubbleking
    Apr 18, 2016 at 15:16
  • I honestly don't know what the concern would be with having a precision square cut would be here. Since PVC cement is a solvent that sort of welds the PVC together, making it stronger than the individual pipe, I just don't understand the concern.
    – alfreema
    Apr 18, 2016 at 19:42
There is a tool that is made for cutting out the PVC pipe in a joint so that it may be used again. That tool may be useful to square up the end of the pipe in this case if you were able to hold the tool inline with the pipe while it shaves off the high part of the pipe. This is what one example of the tool looks like.
These are used to chucking up the tool into a good sized electric drill (AC powered is recommended). The round slug on the end of the tool keeps the cutter centered in the pipe so that the cutters will shave off the PVC pipe in the coupling. In your case this may allow you to square off the pipe in your drain if you can hold the tool steady whilst it shaves off the high part.
Note that not all PVC pipe shavers are suitable to your situation. Some of them do not have the same type of round slug as shown above. Cheaper ones may just have a thin washer style guide to hold the cutter centered in the pipe. Even the above tool type may not work in your instance if the non-square end of your pipe is too angled.
When searching for these the search phrase you want is "PVC fitting saver".
  • This is a brilliant answer and precisely the type of tool I had hoped would exist. I am curious, though, to get your opinion on if my situation truly requires a perfectly squared cut. With the hub connection fitting tightly over the pipe end, solvent cemented, and having a good amount of overlap, even if it doesn't bottom out squarely all the way around, will this really affect the integrity of the drain?
    – bubbleking
    Apr 18, 2016 at 15:14
  • As long as the solvent cement seals the pipe with good engagement and the drain is level then you are good. A square end is desirable but not critical.
    – ArchonOSX
    Apr 18, 2016 at 20:08
Being that you are repairing an unpressurized drain, the squareness of the pipe end is not nearly as critical as a pressurized supply line. Just make sure to clean and prime the pipe prior to applying solvent cement. Additionally, if you have a level handy, lay it across the drain once the fitting is in place to to ensure proper placement.
Side note: It may help to know that you aren't really gluing the pipe together, but you are creating what's known as a solvent weld.
  • This is great information. I wasn't sure why the square cut was so important, but that is a great point about pressurized vs. non-pressurized. I'll be cleaning, wiping with an emery cloth and priming the pipe before applying solving cement. Regarding the leveling, are you saying I should apply some force to the drain to push it into the most level spot as possible while the cement cures? That is, should I take advantage of the play in the joint to move it a few degrees? I know the pipe isn't exactly level, but the drain kit I have provides some adjustments and shims to help with that.
    – bubbleking
    Apr 18, 2016 at 17:38
  • Your are correct concerning the leveling. It probably won't won't move a lot, but sometimes an 1/16 is all you need to make perfect.
    – bigbull15
    Apr 18, 2016 at 18:30
Well I am a guy that can't cut a straight line. For large pipe (2",3",4" etc.) one good way is to install two stainless steel hose clamps at the cut separated by the width of the saw blade. I use a wood miter saw which has small teeth and a wide blade for a clean cut.
For the situation like the bath tub drain mentioned here in use one stainless steel hose clamp and a file, sander or small saw to cut against the hose clamp. The hose clamps are somewhat self centering but can be positioned at desired marked location of the cut. The stainless steel being harder than the PVC forces the saw to the desired cut location. For smaller size pipe the handheld PVC cutters pay for themselves and take the guess work out of cutting.
