When installing an old work low voltage ring/bracket in a room (for a network plug), I cut the hole where there is a block behind the drywall.
The block is what looks to be a 1x4, going vertically up and down at las far as my hand can reach. I cut the hole right in the middle of the 1x4.
So now the swing clamps in the bracket won't latch properly as they wont go far enough to go behind the block.
I sawed the 1x4 at the top and bottom of the hole in a so the clamps got a little grip, but that's not gonna hold if somebody pull a cable from the plug.
Any idea on how to fix this?
Are there any brackets with swing clamps that would go further back?
