I've been having an issue for a while now where my chandelier light fixture installed with six Cree 60W LED replacement bulbs flickers when I raise my traditional dimmer to max brightness. As I understand it, the reason for this flickering is because the Cree bulbs can not handle the high current induced by the dimmer. My budget is pretty small right now and I would like to avoid buying $25 led dimmers (since I have several fixtures with traditional dimmers that would need replacing).
So, one possible solution I was thinking of was to simply use one or two incandescent light bulbs in place of the LEDs to increase the resistance of the circuit and hopefully end the flickering issue. My only concern with doing this is whether it will damage the LED bulbs in any serious way (I'm okay with any funny colors that may result).
Thanks.
