Moved into an apartment that has MR16 bulbs on the ceiling. A total of 7. Replaced them with 5W Leds and it started flickering. If I use one halogen and 6 LEDs, it doesn't flicker and works fine. The lights have a dimmer switch but i don't want to use it or I keep it on full brightness only. The LEDs are non dimmable. Please advise how to correct the problem.
- Should i search for a daylight halogen and use that in one socket to avoid the flickering.
- Should I call the electrician and disconnect the dimmer?
- Any other solution
