I have a E27 T210 connection for a lamp holder, and there are no screws to fix wires into. It is also unclear how they push in.
If this a push connection are the wires supposed to be soldered?
  • Some photos might be helpful.
    – Tester101
    Commented Oct 2, 2015 at 12:54
For push-in connectors, the wires do literally just push in. There is usually a gauge printed on the unit to show how much insulation to strip. Soldering stranded wire is helpful but not necessary if twisted tightly. There is usually also a tab to press with a flat screwdriver to release the wire (in case you need to remove it).
(Click image to enlarge)
IMG:
