An existing lamp holder has cracked and will not hold a lamp. How can I remove the existing broken lamp holder without cutting wires? The pictures are of one I can cannibalize.
You probably can't. I would just cut them back an inch or two on both the bad one and the "donor", then use splices on the wires.
| improve this answer | |
They are generally soldered on. The 2nd picture shows the plastic covers, which push in, which inside is where the wires are soldered on. You'll need to find a way to pull these out. Once they are out you can melt the solder with a soldering iron to remove the wires.
