This is used to automatically close my shelf doors.
- What is its exact name so that I may google better for information.
- More specifically, I have a similar one with a damper added on top which is getting slack and mis aligned, possibly because of rust (its right under the sink and frequently gets wet). Is it possible to make it last a little longer and tighten it or adjust it in anyway or would I need to just replace it?
Specifically this is the problem I am trying to fix And this is the faulty hinge
