I am holding four 44 inch long 4x4 pieces of lumber which I have sanded down to the finish I require.
I intend on using a tap & die attachment set for a corded drill to progressively drill two 2 inch holes into the corner of each piece of lumber where I will thread 1/2 inch width steel rods into, attach to the table top, and secure the legs with hardware.
Does this sound feasible? The table design is corner braced.
