I'm building a tall, large standing desk and removable legs are required for this to fit through doors. I'm using pocket screws to attach the aprons (hardwood maple) the table top (birch veneer hardwood plywood). Screws are 6" apart
Would adding glue between the aprons and tabletop be beneficial for structure? Or would the glue not have a benefit because of the thin birch veneer that it's being glued to? Or would glue cause problems if the wood warps (I live in dry, Colorado climate and warping may not be an issue).
