Bit of a newbie to DIY here.
We've moved in to a house that came with a summer house but the double doors were a bit wonky/wouldn't open easily without breaking in the door. I need to get 4 new hinges for the doors but I'm not sure where I can find these ones. I've looked online on UK sites such as Screwfix but as I'm not sure of the particular name I'm not having much luck.
I've attached a drawing (sorry it's the best I can do as my camera isn't working). My Paint skills aren't the best, it's actually a cylinder shape and half of it spins/moves (this is what is broken/doesn't move anymore so it breaks in to the door).
enter image description here Picture from appararent duplicate question Cheers, Jack
  • Could it be as simple as a need for lubrication? If not, can you remove one of them for long enough to take it to a specialty door hardware place? May 21, 2015 at 13:38
Barrel Hinge:
But note that there's nothing intrinsically wrong with fitting a completely different type of hinge.
You obviously need hinges explicitly intended for outdoor use. Not like these
  • Also known as a 'lift off hinge'.
    – user109695
    Dec 7, 2019 at 1:55
It may be a rat tail hinge.
(Image Source)
It doesn't totally look exactly like it, but might be some sort of style of it.
