I am in midst of finishing the roughed in full bath and want to put a bar sink on the wall behind the tub. I will add pictures later- once I am able to get some good shots....
The way it was roughed in- I have the lav sink on the left, and the toilet on the right. On the opposite wall is the tub drain. Here is a mock up: https://drive.google.com/open?id=0B3vdRz1ABOmaVmxCUWJ3dVZIYzA&authuser=0
I am assuming that the rough-in for the full bath is correct, and everything is vented properly. The solid red lines are what is there today as well as the vent stack- at least what I believe is there. I can only see the rough ins sticking out of the floor for the toilet, and the tub drain in the ground. The dashed lines are what I was planning to do. My plan is to tie the bar sink drain to the tub drain- since they share a wall. I was hoping that however the tub is vented- the bar sink would just use the same vent. But after reading many threads on here I am not so sure. If this is not a good idea, please help me to figure out what I can do.
Thanks!
MORE INFO: Thanks pdd. I am not sure my picture is as clear as it should be. The lines I had drawn were all flat- meaning they are under the slab so I am guessing where they go. I just assumed that the rough in was vented properly. So if I assume that the tub is upstream of the toilet and vented properly- can I tee off the pipe that is in the slab for the bathtub and connect the drain for the tub and the bar sink? And add a vent for the bar sink and run it over to the vent across the room that is for the bath lav?
New vent |
| | vent for
sink tub | toilet and
| | | bath lav |
P P- each has P-trap |
\ / toilet |
|- drain in slab | |
drain to septic system \
