I am building a tree house. I will cut two support beams from oak to support the building. How much weight will a 4"x8"x20ft oak beam support?
I will be working between two trees.
    Those beams are going to weigh 200 to 280 pounds each Commented Feb 24, 2015 at 20:15
    A 4"x8"x20' oak beam is worth thousands of dollars. There's nothing comparable on Woodworker's Source, but the equivalent volume in 2"x2" blanks comes out to $1120. Sell the lumber and buy some I beams ($260 for a 6"x6"x20')!
    – Doresoom
    Commented Feb 24, 2015 at 20:26
    Good luck finding a 20ft oak "beam" anywhere. Maybe 150 years ago that would have been available, but not anymore.
    – William S.
    Commented Feb 26, 2015 at 20:04
The strength of the wood beam will depend on the specific species of oak, the grade of lumbar, whether there are any cantilevers, side bracing, and other factors. But 20 ft seems like a very long span for a 4x8. Glancing at some load tables I would say you're in the ballpark of only a few hundred pounds capacity, which is not sufficient when you take into account the weight of the structure, the weight of occupants, snow, etc. (Don't take my word for it: you must get a more accurate number before you start building). (By the way, where are you going to get a piece of solid oak that long??)
Another side note: you don't say anything about the design of the tree house but be careful about how you connect the trees. When the wind blows the trees will move independently and you need to make sure that your structure isn't rigidly fastened to both trees. There are many examples online about how to make a platform that is fixed to one tree and slides at another. If you don't allow for movement of the trees you risk damaging the treehouse or the trees themselves when a gust of wind blows.
  • This has really good points so +1 but we need to see a design to answer better. Also on your notes on wind... Do not make a sail in between the trees.
    – DMoore
    Commented Feb 24, 2015 at 17:56
  • awc.org/codes-standards/calculators-software/reversecalc lacks the option of dealing with 4x8 (seems stuck on 2x material) but does include red, white and mixed oak for species. It suggests 2x12 on 12" spacing for a 20 foot span, wet conditions, with load reduced to 30/10 and deflection at l/180 - which tends to support the idea that 4x8 is just plain too small to work.
    Commented Dec 4, 2015 at 17:38
-2
I would suggest you contact a structural engineer or local building code office. They will be able to provide you with load bearing numbers for common lumber, i.e. spruce-pine-fir; your oak timber will carry considerable more weight. When we were kids (back in the sixties), the material used was limited only by what we could scrounge from scrap lumber piles, filtch from neighbors, or drag home from a construction site. Our treehouses were no architectural marvels, but nobody ever died from the treehouse collapsing on us either. But that was a day when three nine year old kids had more sense that a lot of adults today. Just have fun with it, and let your kids help.
