I have an outlet which gives electricity only when corresponding wall switch is on. I need to remove the wall switch because I need to put a cabinet on it's place. How do I make the outlet permanently "on"? Is it enough to just connect together Live and Neutral wire in the switch, then remove the switch? In other words, would it make a short circuit? :)
1if you removed the switch the box must remain accessible so you can't put a cabinet in fron of it– ratchet freakCommented Dec 24, 2014 at 16:32
1Why would it have to remain accessible? I just want to make it permanently "on", like all other outlets.– cincplugCommented Dec 24, 2014 at 16:36
1All junction boxes must remain accessible removing the switch and connecting the live to the switched live and closing it up makes the spot where it was a junction box.– ratchet freakCommented Dec 24, 2014 at 16:41
Add a comment
1 Answer
- Turn off the breaker
- Remove the face plate. You should find two (usually) black wires on opposite ends of the switch.
- Remove the switch, and join the two black wires with a wire nut.
- Turn on the breaker, and test the outlet
- Put a blank face plate on the (now junction block)
- Install cabinets
- Cut a hole in the back of the cabinet to access the junction box.
Don't you need to cap the ground wire as well between step 3 and 4? Commented Jul 9, 2018 at 1:36
