I have a light switch that powers an outlet when it's turned on. I want to remove the switch, connect the wires and make the power in the outlet permanently on. In that case, what am I supposed to do with the ground wire that goes into the switch? The outlet is already grounded so can I just cap off the ground wire that goes into the switch?
  • Is there a light in the room that is controlled by another switch? If not this is a code required “switched” outlet for a light. If there is a separate light just nut the wires and put a blank cover on but note what the wiring control for future reference.
    Commented May 21, 2019 at 14:04
  • The light in the room is connected to the aforementioned outlet.
    – Hans
    Commented May 21, 2019 at 14:07
  • Is it an half always on/half switched? it is much easier in that case. Commented May 21, 2019 at 14:10
  • You need a switch in the room in the usual location for a switch, and it needs to turn on a light. Obviously you will develop a way to turn on a light, and you and your family will learn how to grope around in the dark to light it. However, that will not help the EMT who is there to save a family member's life. First responders and guests need to be able to turn on lights quickly using normal methods (switch in the expected place). Commented May 21, 2019 at 15:33
With the light connected to the outlet it would violate code not to have the switch, if you added a ceiling lamp that was switch controlled then this outlet could be wired hot without violating code.
  • would a wireless switch (one looking like a normal switch) that controlled room lighting be up to code?
    – dandavis
    Commented May 21, 2019 at 18:03
    I believe it would meet code, I have not seen anything forbidding smart switches. And remote switch means (controlled by computers / PLC’s) are how most industrial buildings work. The local switches are an input to the computer or PLC.
    Commented May 21, 2019 at 22:25
