Even in my moderate climate zone this dreaded winter starts and one room in particular (the living room) drives me nuts: It feels so terribly cold, I can "feel" small drafts but no obvious source. The most obvious one are the windows though and just holding my hand close to the windows I can feel a cold draft coming towards me ... and this with a measly 55-60F outside.
It is a 100 year old house but has dual pane retrofit vinyl windows (I think from the 90s or 2000s):
Here is another zoom:
I really don't see any obvious holes or issues. It is always suggested to "caulk around windows" but where? I can buy a foam pad and put it under the sash. But I don't think this is the main issue, it's not just from under the bottom sash.
Where could this window be leaking air and short or replacement, what is the most efficient way to seal it? We never open these windows so it could be a solution that does not require the sashes to be movable.
