I would like to move this toilet to the wall on the left side of the picture:
existing toilet
The bathroom is in a flat with two flats above, so the soil pipe is actively used by these other flats. Here is the current plumbing:
current waste plumbing
In order to move the toilet I would like to move the waste pipe so it is plumbed into this side of the soil down pipe:
the side I would like the waste to be plumbed into
Would this be possible, to add plumb a new toilet waste pipe into this side with minimum disruption? If so how would you recommend achieving this?
  • Is that some kind of wall-drain toilet?
    – Huesmann
    Commented Aug 18 at 15:51
After doing some research I found this which is a near identical situation:
https://community.screwfix.com/threads/soil-stack-branch-replacement-help-please.239968/
TLDR;
  1. Attempt to rotate the branch, this maybe possible if it is pushfit.
  2. If it won't budge the branch needs to be cut out by making two cuts above and one below. Clips and straps are needed to secure the soil pipe while doing this.
  3. A slip socket, or a flexible 110mm connector (with jubilee clips) will be needed to fit the new branch in the new position.
