My 5yo 4.5 ton variable Bosch air handler is sweating a bit, in my spray foam attic that is averaging 80° and 65% humidity. I've recently washed the coils outside, tried to vacuum the condensate PVC pipe from the outside, but there's still 1/8th inch of water in the safety pan where it's sweating upstairs.
Is it not a good idea to add a clean out tea after the P-trap? The three-quarter inch PVC drain does a couple 90° turns and heads straight down my wall cavity into the crawlspace where there's another 90° bend draining it right outside in my backyard. It's a steady trickle of water. Link to video of the setup
