There are so much marketing for LVP and I am just trying to figure out what parameters I should be looking at on the data sheets for a successful install.
The subfloor slab
<1mm flatness in 8'
3/8" sloped over 22'
Hardened with Lithium Silicate after 28 days
low water emissions from concrete
concrete is slightly below grade so temperature is stable
Looking for in LVP
Herringbone pattern - We like it
Good Static load resistance (usually measured in how many PSI causes certain deflection) - will have 1500 lb safe that sits on a thick rubber mat)
Abrasion resistance (Wear layer resistance to scratching) - Kids mostly and casters (though will use a plastic protector)
5.5-8 mm thickness (to match existing tile)
Gen Notes/Rambling:
With how flat the floor is, I think the locking mechanism won't be under as much strain... however with thermal cycling the heavy weight of a safe would keep the floor fairly static and the rest of the floor would have to move. I think its minimal with the slab being slightly below grade.
I have looked at the following parameters
Static Load Test - a psi that causes 0.005" compression in the flooring
Maximum weight of item allowed in warranty - example was 1500 lbs, but no surface area was given.
