I'm planning to replace a linoleum floor with LVP. The transition strip/threshold matches the wood floor, but since the LVP is a few mm thicker than the linoleum, I don't think it'll fit once I lay the new floor.
My questions are:
How do I remove this transition strip without damaging the wood, so I can get a better idea of what I'm working with?
Once the LVP is put down, what should I replace it with? The only thing I can think of is to cut it back to the middle of the door jamb, and then add another low-profile threshold strip on top of it to cover the junction with the LVP.
