As part of a bathroom remodel, we are looking at installing a bathtub with a strange drain setup. The tub has the overflow and main drain connected with this black plastic tubing that ends as a corrugated hose that needs to be connected to the drain trap somehow. The instructions are not very helpful on the topic:
This installation guide does not include details of waste connection.Final decision about installation of waste connection should be taken by a contractor
This diagram is provided, clearly the tubing should not just be loosely laid inside of the drain pipe. Is there an accepted, correct approach for this?
Would I just stub out the drain from the trap and use a flexible coupling ("Fernco" coupling)? Or would a slip joint be better? I do have access from underneath, which might satisfy access requirements for the slip joint, but it would still seem like a poor choice. Is there a preferred / standard approach to these types of tub drains?
This is located in the USA, and the tub is for sale (and on display) at a major big box store, so this is not a funky, one-off import.
