I want to put up a track around the ceiling of my basement for the cats to run around on. Looking at the scrap I have available I believe I have more than enough 1/4" plywood (dunno what kind of wood it is; probably not super high quality stuff) to make 6-8 inch-wide paths around the entire basement.
The basement walls are cinder block and/or concrete, and I have used Tapcon screws successfully in the past for other projects. I've also used these (https://www.homedepot.com/p/Everbilt-6-in-x-8-in-White-Shelf-Bracket-15418/202034287) metal shelf brackets on another project to support a cat's weight, and there have been no problems after more than a year of one of those holding up a single 8"x10"x3/4" platform.
My main question is the following -
How far apart can the brackets be to reasonably and safely support a single cat walking along the 1/4 inch plywood? Intuition says that 12 inches might be a bit overkill and 18 inches might be a bit wide. I don't have experience here, though, and I'm not an engineer.
I went looking at a sag calculator once. It indicated that I needed to place the brackets really close together if I wanted to avoid being in their "extreme sag" category when max point weight is 15 pounds (usually less). Just a few hundredths of an inch of sag would change the category from "good" to "acceptable" or "acceptable" to "extreme", and that seemed a bit tight of a tolerance to me given that I am placing practicality over aesthetics for this project.
