I'm working on wiring spotlights for my basement, which includes three bedrooms, two bathrooms, a kitchen, and a hall. Each room has different dimensions.
For example, I have a rectangular room measuring 3m x 2m. I want to distribute the spotlights so that the light is as evenly distributed as possible across the room.
I initially tried placing the spotlights equidistant from each other. I divided the 3m length by 3 spotlights, placing them 1m apart, with each light half a meter from the walls. For the 2m width, I used 2 spotlights, placing them 1m apart and half a meter from the walls. However, this setup doesn't seem to provide adequate lighting as there are large gaps between the lights.
How can I determine the right number of spotlights for a room of length ( L ) and width ( W ), and how should I distribute them to achieve the best lighting results?
