I've got a basement room that is not connected to the rest of the basement, is not heated and has poor insulation. Our living room is right above that basement room. The ceiling/floor between the two rooms is concrete and the only insulation between the two is a drywall ceiling in the basement room that is dropped about 4cm (~1.6in) + plaster.
The two rooms are well enough connected so you can smell solvents in the living room from paint drying in the basement.
The basement room is pretty low already, so the amount of insulation will be limited.
My question is:
What's the best way to insulate the basement from the living room?
Options I've been considering:
- Tear down the drywall ceiling, replace with styrophoam/rock wool panels.
Pros: good insulation, DYI.
Cons: a lot of work to destroy something that's already there, styrophoam and rock wool potentially release toxic/carcinogenic material. Relatively expensive. Styrophoam adds to the fire load in a basement storage room. - Blow-in insulation.
Pros: I can use what's there; it's probably a matter of minutes to get installed. Good, cheap, non-toxic, eco-friendly, flame retardant insulation material.
Cons: I don't think that's something I can do myself without expensive equipment and without the experience, can I? It may be hard to get a professional for such a small job. - Spray foam.
Pros: Cheap, easy DYI(?), good insulation, non-toxic once dry, flame retardant when using the right foam.
Cons: I haven't read much about using spray foam for drop ceiling insulation, so I don't know if this is practical and what the potential pitfalls are.
What other options am I missing? What other Pros/Cons am I missing with the options I've listed?
