I have a subpanel that feeds two pieces of HVAC equipment - a minisplit and a heatpump compressor. Their MCA (minimum circuit ampacity) figures on the name plate are 16 amps and 24.1 amps, respectively. These, of course, add up to 40.1 amps.
Is it code-compliant and safe to feed this subpanel with 8awg NM-B protected by a 40-amp breaker in the main panel ?
Purely based on the numbers given, the answer would be no. But I'm aware that the NEC has cases where some wiggle room is given, such as upsizing a breaker (e.g. 60-amp breaker on a circuit wired with 6awg). Is this one of these cases ?
