I have to rewire the line-side conductors on this disconnect switch to reach breakers in my new panel. The line-side conductors exit through the left side of the switch. The 50A disconnect was installed by my solar installer.
I have 2 questions:
1: Should I crimp ferrules on the the stranded #6 and #8 conductors (load side is #8, line side is #6)? As you can see in the picture below, the screw does not capture a lot of the strands. The lugs are rated for 14 - 1/0. If so, are there any ferrules where I don't need an expensive (>$50) crimper? Any other suggestions on how to best land these conductors?
2: The grounding conductors are currently crimped. I don't have that crimping tool. Would it be acceptable to tap a hole for a lay-in lug and connect the load-side ground wire to that new lug and get rid of the crimped connection?
Any other things I should be looking out for while re-wiring this?
Thanks
