I have a Quiko QK-CE220BATRL4 circuit board controlling two Quiko motors on each gate. It has been working fine for the last 3 years. Now when I click the remote button the circuit board still registers the press but the gate does not open.
The display on the circuit board is "9a" which the instruction booklet describes as:
9a: Motor A is in thermal protection state
The only reference to this in the booklet is a "Motor Thermal Test" which simply says the working cycle cannot be started if the motor is in thermal protection, which is, I assume, why my gate will not open or close.
So the question is what is thermal protection state, why has it suddenly occured, and what should I do to fix it?
I have obviously tried turning off and on!
