I have an existing 110V outlet behind a weatherproof cover in my side yard, on the exterior wall. Above it the backyard patio company has installed a small metal outdoor electrical box (6”x12”x5”) that has a setup to convert bare wire to a 3 prong plug along with some fuse and a wireless controller for backyard lighting.
I would like to get a larger outdoor electrical cabinet (16”x16”x8”) to enclose both. Is it okay to cut a single gang opening in a weatherproof electrical cabinet for the 110V outlet? Does that violate code? Break best practice? Or alternate options that would work better? Appreciate any help on this!
Thinking of using an enclosure similar to this: https://www.homedepot.com/p/VEVOR-2048-cu-in-Electrical-Enclosure-Box-16-x-16-x-8-in-NENA-4X-IP66-Junction-Outlet-Box-Fiberglass-with-Mounting-Plate-DQXFSBLG40X40X201V0/320686901#overlay
