I have an newly installed, single outdoor outlet on my patio and had the electrician pipe in conduit (yep... live in Chicago.... it sucks), 12 gauge wire, and install a 20 amp GFCI a new 20 amp breaker for a dedicated circuit to this one outlet. Easy done.
The outlets are the typical 3 prong / Type B / USA style for your normal household appliance.
The outlet is used for electrical cooking on the tabletop and I know we have tripped the circuit before on an unknown outlet running two cook tops (not sure if it's 15 amps or 20 amps...).
Could you use like 8 gauge wire to carry more amps at 110V... and still use the normal household outlet? Are there code worthy / safety testing, receptable over 20amps / outlets / breaker combinations that come with a Type B plug?
So the question is, is there a GFCI, Type B outlet, that goes above 20A?
I've never seen anything like that, but we have such a goofy usage of this one outlet I've got my brain wondering now. (In retrospect, we could have a done a double gang outlet, and run two sets of 12 gauge wires -- but theoretically these two cook tops should be fine with 20A, but Mr. Conduit guy is coming back for one last outlet and we could rewire more current, I guess -- this run is really ugly already, I'm not actually sure we could fit 8 gauge across my basement to this outlet).
