I have a Schlage Encode and unlocking and turning the thumb turn. I was able to take it apart but doesn’t seem like it’s catching when I turn it manually. Also a piece fell out that I’m assuming may be important. Any ideas on how to fix?
Deadbolt picture
This video is of my freely turning the part to move the tongue
That is a broken deadbolt. As you say, it appears to be missing an important component. The Encode uses a tapered deadbolt so that it can more easily be operated by the small motor inside the lock, so I wouldn't expect it to be reliable with a standard deadbolt. You will likely need to go directly to Schlage for the part.
  • This part is definitely not serviceable without serious compromise in reliability. The failed mechanism is most likely something like a gear tooth that broke off, so there's just no way you can repair that to anywhere close to the original strength.
    – Nelson
    Commented Feb 6 at 1:19
    Yes, I'm referring to replacing the deadbolt, not repairing it. By 'the deadbolt' I mean the assembly shown in the video, not the whole deadbolt lockset.
    – KMJ
    Commented Feb 6 at 6:51
  • Yep. The bolt mechanism shown is a single replaceable part, not really worth repairing. Think about the hassle if your repair lasts just long enough to engage the lock and then refuses to retract the bolt...
    – keshlam
    Commented Feb 6 at 15:13
    I was going to buy a standard Schlage deadbolt to replace but good to know these details. I actually was able to call Schlage (their customer service line takes forever) and they offered to ship a new one and at the same time since I couldn’t use my door lock they said to go buy a normal deadbolt and install temporarily while I wait for the replacement. They’d the reimburse me for that purchase and apologized for the inconvenience. Top notch customer service. Commented Feb 6 at 15:51
  • Good to hear! Also it's nice to know a regular deadbolt will work, at least temporarily. I bet it's a little more finicky than the tapered one this comes with, so keep an eye on it until you get the right part back in place.
    – KMJ
    Commented Feb 6 at 16:56
