Radiator is cold after I bleed it water comes out fine, check the TRV and the pin is fine moves in and out fine it still no heat. All of the other radiators are hot
1Welcome to Home Improvement, please take the tour to see how things work a little differently here. When you're done, please edit your question to include more info like, is this water or steam, what floor is the radiator on, what's the plumbing layout, where is this in relation to other radiators. Also, please actually ask a question not just make some statements.– FreeManCommented Jan 27 at 1:00
That doesn't totally rule out the TRV, but does rule out the head. Replacement of the complete valve may be necessary, but not as a first step. Has it always been like this? Is it stone cold top snd bottom, or does a little bit of it get a little warm?– Chris HCommented Jan 27 at 18:56
Also I worked somewhere where the radiators at the top never worked properly. They needed bleeding every day, and still never got a flow, but bleeding with the system on got some hot water in there. Did you bleed with the system hot or cold, and if you bled with it hot, how hot did the radiator get then?– Chris HCommented Jan 27 at 19:01
Add a comment
1 Answer
Check the lockshield valve at the other end of the radiator. It should be open a little, but not so much that this one radiator "steals" all the hot water from the other radiators. The lockshield valve usually has a plastic cap, which pulls off. Then you need to find a spanner that fits, or use pliers, to turn it.
If the lockshield valve is already open, the radiator may be blocked with sludge.
